Kris222
May 30, 2018Aspirant
RBR50 / RBS50 - No Ethernet backhaul with new firmware
I have a set-up with a router and two satellites with ethernet backhaul.
After a satellite auto-updated to 2.1.4.10 my internet died.
Then I had to do a manual update on Router and other satellit...
Cmo1
May 31, 2018Apprentice
Same issue here. I had to make sure Daisy chain was turned on, or I get nothing. Hopefully yours may have been turned off.
Kris222
May 31, 2018Aspirant
Thanks for the help. I’ll try - even tough they are not Daisy chained (star)
Best,
Best,
- Cmo1May 31, 2018ApprenticeYes. Same here. I'm currently only using one wired satellite because my house is only 1700 square feet, but I still had to have that in or it did nothing.
- Kris222May 31, 2018Aspirant
Hi Again!
Daisy chain was on - Disabling it did not do the trick. Everything was fine with the last firmware. This is kind of a dealbreaker for me...
I can't get in touch with Netgear support - Does anybody know of a way??
Best, J
- Cmo1May 31, 2018ApprenticeThat's really weird and it would be a deal breaker for me too. Only thing I could think is factory reset without the cord connected. Let everything connect and satellites sync and then reconnect cords like everyone else tries. But I'm assuming you may have already done that.
