Kris222
May 30, 2018Aspirant
RBR50 / RBS50 - No Ethernet backhaul with new firmware
I have a set-up with a router and two satellites with ethernet backhaul.
After a satellite auto-updated to 2.1.4.10 my internet died.
Then I had to do a manual update on Router and other satellit...
May 31, 2018Guru - Experienced User
Any network switches in the mix? If so, Mfr and model#?
What is the mfr and model# of the ISP modem the Orbi is connected too?
What other devices do you have connected to the Orbi router?
Then I had to do a manual update on Router and other satellite. (Because Orbi doesn’t detect latest version?!?!?)
However, now my Ethernet backhaul doesn’t function anymore. Every time I add ethernet, all network activity dies. No Ip or anything. Just as before Orbi support Ethernet backhaul.
My house is concrete - I have extremely bad reception on the wifi backhaul. Deply disapointing. I have spend hours on this – Please advise
- Kris222Jun 05, 2018Aspirant
Hi Again.
Reset didn't work :S
My ISP modem is Optic from Alcatel Lucent. It's hard fixed by IPS to wall - so I can't check model.
I also have a simple Sempre unmanaged low power 1G/100/10 8-port switch.
Please advise.
Best, Jeppe
And I have:
- NAS
- Sonos
- Philips Hue
- Logitech Pop
and about a 1000 iphones and PC's connected as well :)
