Kris222
May 30, 2018Aspirant
RBR50 / RBS50 - No Ethernet backhaul with new firmware
I have a set-up with a router and two satellites with ethernet backhaul.
After a satellite auto-updated to 2.1.4.10 my internet died.
Then I had to do a manual update on Router and other satellit...
Kris222
Jun 05, 2018Aspirant
And I have:
- NAS
- Sonos
- Philips Hue
- Logitech Pop
and about a 1000 iphones and PC's connected as well :)
Cmo1
Jun 05, 2018Apprentice
Try 2.1.4.16 released just last night with a factory reset. I had to make sure Daisy chain was active.
- Kris222Jun 05, 2018Aspirant
Excellent. However - The RBR50 link contains the RBS file. And now I'm running with two different firmwares again... :O
- Cmo1Jun 05, 2018ApprenticeThat's odd. The links I followed gave me separate files for rbs and rbr
- Kris222Jun 07, 2018Aspirant
Hi Chris/All and especially Netgear, if you are listening.
The new 2.xx.16 worked fine for one satelite on Ethernet backhaul - but as soon I attach nr. 2 to ethernet - everything dies, internet and intranet.
Arghhhh. :)
- st_shawJun 07, 2018Master
The links work correctly for me on OSX with Safari and on Windows 10 with Edge.
Another user reported some problem with Safari and trying to download both firmware files at the same time.
Try it again, and only download the RBR file.
- Kris222Jun 07, 2018AspirantGot it, thanks. Five hours after - the link worked fine (Firefox +Chrome)
Best,
