Cidion's avatar
Cidion
Tutor
Oct 17, 2021
RBR50 + RBS50 + RBW30 / Wifi drops every day to under 100Mbps
Not sure how to troubleshoot this. But every day my wifi drops down to 75-90Mbps, where normally it's in the 500Mbps range.
Only way I have found to get it back up to 500 is to unplug router, unplug the ethernet from the ISP, wait a few minutes and put it back together.
Firmware is up to date on the routers. Wired speed are still in the 800-900Mbps range.
Any ideas? I've had these about 3 years. Have they run their use cycle? Time to buy new brand?
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    Does the problem still happen if you turn OFF the RBW?
    • Cidion's avatar
      Cidion
      Tutor
      I can try and answer some of those router questions after I get home later today, but I can start with this extra info.
      This is a new condition. Meaning, for a couple of years we havent had this problem. But just noticed it recently. We haven't changed any locations of any devices, or changed any settings on any of the routers, or even added any new devices in the last year, except for maybe a smart plug for homekit.
      Closest neighbors are maybe 1000ft away on one side, the rest is woods.
      Home is about 800sq ft units are on three corners of the house.
      I'll still check all of those settings when I get back, but is this a familar problem? Wifi signal dropping speed after a while?
      • FURRYe38's avatar
        Also any new wifi neighbors that recently moved into the local area?
