billypatel
Jan 15, 2021Tutor
RBR50 / RBS50 / UK / Virgin meda - Satellite drops connection
I have a RBR50 connected to my virgin media router, with a sattelite positioned at the opposite corner of the house, the satellite connects ok and gives me 100mb download speeds which is perfect, but...
billypatel
Jan 23, 2021Tutor
So i have now set my VM router to router mode, and set my orbi to AP mode.
The rbr50 now randomly disconnects from the router, i see this in the logs:
[Internet connected] IP address: 192.168.0.39, Saturday, January 23, 2021 13:55:21
[Internet disconnected] Saturday, January 23, 2021 13:50:51
[Internet connected] IP address: 192.168.0.39, Saturday, January 23, 2021 13:50:35
[Internet disconnected] Saturday, January 23, 2021 13:50:18
[Internet disconnected] Saturday, January 23, 2021 13:50:07
[Internet connected] IP address: 192.168.0.39, Saturday, January 23, 2021 13:49:27
[Internet disconnected] Saturday, January 23, 2021 13:48:09
[Internet disconnected] Saturday, January 23, 2021 13:47:25
[Internet disconnected] Saturday, January 23, 2021 13:47:21
[Internet connected] IP address: 192.168.0.39, Saturday, January 23, 2021 13:47:10
[Internet disconnected] Saturday, January 23, 2021 13:47:02
[Internet connected] IP address: 192.168.0.39, Saturday, January 23, 2021 13:46:55
[Internet disconnected] Saturday, January 23, 2021 13:46:49
[Internet connected] IP address: 192.168.0.39, Saturday, January 23, 2021 13:46:23
[Internet disconnected] Saturday, January 23, 2021 13:38:45
and the device is a solid pink colour.
When the rbr50 disconnects, i quickly connect my laptop to the ethernet cable to test it and it connects ok.
Does anyone know what else i can try to help with this?
vajim
Jan 23, 2021Master
billypatel wrote:So i have now set my VM router to router mode, and set my orbi to AP mode.
If I were you I would get rid (if possible) of whatever other 'router' you have and run the Orbi/sats by themselves.
In this forum there are lots of reported problems being reported by folks who try to run 2 routers.
- billypatelJan 23, 2021Tutor
Im not sure i can replace, as the virgin media hub 3 uses a coaxial connection (i think its called that) whereas that doesnt exist on the orbi router, i did have the VM router in modem mode and the orbi in router mode, but i swapped it to see if that was causing me the issues.
- vajimJan 23, 2021Master
billypatel wrote:Im not sure i can replace, as the virgin media hub 3 uses a coaxial connection (i think its called that) whereas that doesnt exist on the orbi router, i did have the VM router in modem mode and the orbi in router mode, but i swapped it to see if that was causing me the issues.
You may need to get a new seperate modem. I would check with your ISP to see what works with their system.
here's something that might help:
https://community.netgear.com/t5/Orbi/Orbi-RBK50-and-Virgin-Superhub-3/td-p/1678276
- Matt84ukJan 26, 2021Initiate
Hello,
I'm using the RBR50 with one RBS50 with Virgin Media (VM) so I can try to assist a little..
Just general information for anyone else, with VM you have to use the supplied router (which they call the hub). They do not allow 3rd party routers or modems on their network and don't offer modems only their hub.
firstly I suggest resetting the RBR and once fully reset switch off. Also leave the RBS off entirely for the moment.
Reset the VM hub and wait a couple of minutes for it to boot up. Then either connect an Ethernet cable to connect to the WiFi using the details supplied with the hub.
naviagte to 192.168.0.1 and change this to modem mode and the hub will reboot. (Should you need to access this menu again the IP will now be 192.168.100.1)connect an Ethernet cable between a port on the hub and the yellow WAN port of the RBR.
switch on the hub and wait at least 5 minutes. Then navigate to 192.168.1.1 and log in with the default details. Ensure you set the RBR to Router mode.Plug in the RBS in another room and switch on and wait for it to boot up - allow 5 mins. Check back on 192.168.1.1 to see if the satellite has linked.
- FURRYe38Jan 26, 2021Guru - Experienced User
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI presume option#2 or #3 should work for you...
Matt84uk wrote:Hello,
