Loccs26
Jun 13, 2020Aspirant
RBR50 / RBS50 firmware update to V.2.5.1.16
I recently updated the firmware as suggested by the GUI and phone app to 2.5.1.16. I was previously on the rock solid, 2.3.5.30. I treid 2.5.1.8 in the past and all of my attached devices failed to s...
Loccs26
UGH, ok thanks.
Jun 14, 2020Guru - Experienced User
I recommend loading from scratch. Sometimes backup configs from older FW version can introduce same or new problems.
You can try it first and see. If the problem continues, then factory reset and setup from scratch with out the backup config file.
Let us know how it goes...
- MareLuceAug 22, 2020AspirantAny update to this?
I tried the over the air updates to this latest from the same version.
It rebooted but never updated.
Repeated over the air firmware upgrade attempt with same result.
I guess this means I should not try it again.- Loccs26Aug 23, 2020Aspirant
I have done the same in the past with no luck. I just use Voxel's firmware and I haven't had an issue since. Google it.
- MstrbigAug 23, 2020Master
Loccs26 wrote:I have done the same in the past with no luck. I just use Voxel's firmware and I haven't had an issue since. Google it.
I's funny you mention 3rd party firmware, such as Voxel.
Every time we install a Netgear router, we trash their firmware and install DD-WRT. The router is faster, less issues and always has the features one would want.
With that said, my RBK53 system is on 2.5.1.16, and am experiencing no issues whatsoever. Currenty it is not ahowing an update.
- FURRYe38Aug 23, 2020Guru - Experienced User
Try a wired installation of v16 FW on the RBS then RBR using a wired PC and web browser. Factory reset the system and setup from scratch.
MareLuce wrote:
Any update to this?
I guess this means I should not try it again.- MareLuceAug 23, 2020AspirantFurry,
My cable modem is a Netgear CM 500
Connected to a
Orbi Ac3000 Rbk53-100NAS
