Loccs26
Jun 13, 2020Aspirant
RBR50 / RBS50 firmware update to V.2.5.1.16
I recently updated the firmware as suggested by the GUI and phone app to 2.5.1.16. I was previously on the rock solid, 2.3.5.30. I treid 2.5.1.8 in the past and all of my attached devices failed to s...
Aug 23, 2020Guru - Experienced User
Try a wired installation of v16 FW on the RBS then RBR using a wired PC and web browser. Factory reset the system and setup from scratch.
MareLuce wrote:
Any update to this?
I tried the over the air updates to this latest from the same version.
It rebooted but never updated.
Repeated over the air firmware upgrade attempt with same result.
I guess this means I should not try it again.
