McOrbi's avatar
McOrbi
RBR50 / RBS50 Firmware Version 2.0.0.74 upgrade availabillty in UK Orbi versions
Does any know when RBR50 / RBS50 Firmware Version 2.0.0.74 will be released so that the firmware can be upgraded on UK Orbi versions.
I have attempted to do both automatic upgrades:
The auto check comes back with "No new upgrades available"
The manual upgrade comes back with the message this is the wrong file.
The current version installed is RBR50 Firmware Version 1.12.0.18
  • martyfp's avatar
    martyfp
    Sep 26, 2017
    Actually, it is now on the automatic download server, I just went to manually update to .74 (from .72) and the orbi reported that .74 was available so I just did the automatic update.  (I am in the UK)
  • Unzip the file and update with the .img file contained therein.
    Rodney
    • martyfp's avatar
      martyfp
      Luminary
      • McOrbi's avatar
        McOrbi
        Thanks martyfp,
        just updated using the automatic update.
        Cheers
        McOrbi
    • McOrbi's avatar
      McOrbi
      Thanks Rodney, the automatic update server was active today and I have updated the firmware.
      Cheers,
      McOrbi
