1midniterider
Nov 13, 2017Guide
RBR50 / RBS50 Firmware Version 2.0.0.76 issues
I upgraded my RBR50/RBS50 systems to firmware v2.0.0.76 and noticed that DHCP requests are no longer being logged and I can no longer connect to the router using my Android cellphone. Anyone else notice any issues with this firmware version?
Correction: I can connect using my Android Phone, but only a white page is displayed after login.
Curiously the ability to login into my router from Android phone is working correctlry now, but it still bothers me that dhcp entries are not being logged. Was the fix to dhcp to simply turn off all logging?
- CharleemGuide
Hi, on the update page it says to write down all your settings, does this mean that once it's updated all of the settings will need to be put in again?
Thanks.
- A couple of reboots later and all is well, except for the logging issue.
- Stev3DLuminary
I sorry about asking a question about a question, but my Orbi Tri-band RBR50/RBS50 report that they are "current" at v2.0.0.74 -- even the corresponding Netgear support page says that this is "current." Is this a beta or are we talking about different models? Apologies in advance for being a dunce (if that's the case).
- CharleemGuideIt's beta firmware so far.
https://kb.netgear.com/000049562/RBR50-RBS50-Firmware-Version-2-0-0-76-Hot-Fix- Stev3DLuminary
Thank you, Charleem. I am happy to try out the beta since I powerd off my RBS50 (satellite) a week after KRACK was announced and there was no replacement firmware in sight.
