txl's avatar
txl
Follower
May 12, 2020
RBR50 + two RBS50 -- No route between devices on LAN
I have this issue intemittently.
I have an RBR50 with two RBS50 satellites.  Devices connected to satellite #1 cannot connect -- no route, host unreachable -- to devices connected directly to the router or to the other satellite (#2).  The WAN is accessible, however.  Rebooting the offending satellite (sometimes) cures the problem.  I would like a more persistent solution.
Suggestions?
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
    Try updating FW to v16 if this hasn't been tried.
  • CrimpOn's avatar
    CrimpOn
    Could you please describe the connection process.  i.e. trying to "ping" one device from another?  open a web site on a device?  stream a camera?  connect to a file server?
    Do these devices have IP addresses "assigned" to them in the system?
    Orbi is running as a "router" or an "access point"?
