Yogibara's avatar
Yogibara
RBR50 After iOS Upgrade to 16.0 and MacOS to Ventura getting connectivity issues
First, it started with my recently upgraded M1 Macbook to Ventura. Getting SSL errors and logs indicate login refused. MacOS has been stable for the past few hours but my iPhone13 is still having issues. I've done the following to try to resolve:
iOS:
  • Forget network/reconnect
  • enable/disable private network
  • Restart
  • Disconnect/Reconnect wifi
AT&T Uverse Router:
  • Reboot
Orbi RBR50 with 2x satellites (Firmware 2.7.4.24)
  • Reboot entire system.
Overall symptoms:  Most issues appear to be some sort of certificate issues with routerlogin.net and is ONLY affecting Apple OS products in my house.  The loss of internet is random and will come back after a time.  I have a Win10 device as well and it's connected fine.  All iOS devices are running ver. 16.
#rbr50 #routerlogin.net #certificateissue
Unsure if this is related to latest OS versions but I didn't have any issue until within the last 38 hours.
