johnnyb_Ga
Feb 26, 2019Aspirant
RBR50 and adding satellites
I have an Old 1900 Victorian Home 2300sqft that I'm sure has Lead paint here and there.. I bought the RBR50 with the Satellite and it seems like my coverage isn't as good as I want it to be. I'm gues...
Feb 26, 2019Guru - Experienced User
RBS50 satellites would match up to the RBR50. You can add RBS40 and 20s however these have lower connection rates between the base and satellite. Where the 50s have same connection rates.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Chuck_M
Feb 26, 2019Mentor
I had a similar issue with my home. On my RBR50 I added an additional two satellites for a total of three RBS-50s.
I was able to hard wire backhaul for two of them since I had existing cat 5 already pulled and the third uses wireless backhaul.
Works flawlessly.
As mentioned by FURRYe38 , the difference between the 50 series and lower series (40 etc) is the backhaul speed... My personal decision was to ensure max speed of the router, not the satellite backhaul so I went with the 50 series (not to mention it "pure fleets" the firmware and series.)
