johnnyb_Ga
Feb 26, 2019Aspirant
RBR50 and adding satellites
I have an Old 1900 Victorian Home 2300sqft that I'm sure has Lead paint here and there.. I bought the RBR50 with the Satellite and it seems like my coverage isn't as good as I want it to be. I'm gues...
johnnyb_Ga
So each Satellite is feeding off the router?
Presenty my router is at the front of the house and the one Sat. is toward the other end.
I was hoping it would sort of Daisy chain from each other.
If I was to hard wire the furthest one from the router and one stand alone satellite in the middle, would that work?
- Chuck_MFeb 27, 2019Mentor
Deleted duplicate post.
In my case my network architecture is set up as a hub and spoke system with the orbi as the hub. All satellites report directly back to the router.
You can easily implement your daisy chain where one satellite plays man-in-the-middle relaying between the router and a third satellite.
Anytime you hard wire it will be better/faster/simpler
- FURRYe38Feb 27, 2019Guru - Experienced User
johnnyb_Ga wrote:
So each Satellite is feeding off the router? YES
If I was to hard wire the furthest one from the router and one stand alone satellite in the middle, would that work? Yes
