johnnyb_Ga
Feb 26, 2019Aspirant
RBR50 and adding satellites
I have an Old 1900 Victorian Home 2300sqft that I'm sure has Lead paint here and there.. I bought the RBR50 with the Satellite and it seems like my coverage isn't as good as I want it to be. I'm gues...
johnnyb_Ga
So each Satellite is feeding off the router?
Presenty my router is at the front of the house and the one Sat. is toward the other end.
I was hoping it would sort of Daisy chain from each other.
If I was to hard wire the furthest one from the router and one stand alone satellite in the middle, would that work?
Feb 27, 2019Guru - Experienced User
johnnyb_Ga wrote:
So each Satellite is feeding off the router? YES
If I was to hard wire the furthest one from the router and one stand alone satellite in the middle, would that work? Yes
