Doc11
Oct 31, 2018Follower
RBR50 and Apple Airport
I have a FiOS quantum gateway, and I use it with an apple airport system. I have multiple airports around my home which is quite large and rambling. I have never been able to get complete coverage. I ...
Oct 31, 2018Guru - Experienced User
You can keep using the Apple devices. As far as Airports, you would be replacing any of the airports with the Orbi system thus the Airports would not be needed.
If you set up the Orbi wifi for same SSID name and PW your currently using, your devices should connect. Some may need to be rebooted or may have to re-enter the SSID name and PW however.
Set WPA2 and AES only on the Orbi.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
