Teamoverton1's avatar
Teamoverton1
Follower
Apr 13, 2019
RBR50 and CM1150V compatibility
I Installed the RBR50 Router  and all of my  WIFI  multiple outlet  power strips fail to pair.  Does NetGear make a power strip that is compatible or recommend a 3rd party manufacturer that  will pair with the RBR5.    Thanks,
1 Reply
  • FURRYe38's avatar
    What FW is currently loaded?
    NG doesn't make power strips...
    Are these power outlets 2.4Ghz only?
    Had they worked before?
