Jroach
Feb 25, 2020Luminary
rbr50 and IoT/Tablo issue, traffic getting lost
I have a Denon AVR, Apple AX (express), and Tablo that are all buggy...I think for the same reason. Working with Tablo (since it was new) they determined that: "Tablo's local traffic is being lost b...
- Feb 25, 2020
Temporarily reduce the transmit power level. I'll give this a try...I had done this in the past so familiar with the process but can't remember why I didn't leave it at a reduced power level.
Thanks for the tip.
Feb 25, 2020Guru - Experienced User
Do the devices work ok if you turn OFF the RBS and only connect to the RBR?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Jroach
Furrye38, thanks for the reply.
What Firmware is currently loaded? 2.5.1.8 (also a source of pain; attached deice naming issue)
What is the Mfr and model# of the ISP modem the NG router is connected too? My connection issues with Tablo are all inside the house so I wouldn't think that the ISP modem type is realevant. The NG router is the Orbi...maybe I didn't specify the model correctly but it's an RBR50 with one staellite (maybe called and RBS50)
Do the devices work ok if you turn OFF the RBS and only connect to the RBR? Yes
What is the size of your home? Sq Ft? 8500 but the distance between where one of the TV's is located is such that the RBR on its own can't reach that TV.
What is the distance between the router and satellite(s)? It's at least 30 feet. Like above, without the RBS the TV won't stream "well". 30' recommendations is fine for some I suppose but doesn't work for us.
What channels are you using? I've tried a few (including Auto) but will give this a try as the Tablo is new and fails more often.
Any Wifi Neighbors near by? Always :)
If so, how many? A dozen maybe
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. I tried this without any change.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). I don't recall "armor or Circle" but will look and try those.
