JPBOLDY
Mar 19, 2019Star
RBR50 and RBS40v AP mode
If I put my RBR50 in AP Mode to use a different router would the other satalite loose internet connection/functionality (RBS40v) with the RBR50 not in router mode. New to mesh systems.
Mar 19, 2019Guru - Experienced User
No, the satellite will connect to the RBR in AP mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- JPBOLDYMar 19, 2019StarOk thanks
So from cable modem to primary router, then plug orbi rbr50 into a Lan port, (change the RBR50 into ap mode, and use the wireless network from primary router rather than orbi with it now in ap mode- FURRYe38Mar 19, 2019Guru - Experienced User
ALL wifi on the primary router needs to be disabled. You only need the wifi on the Orbi.
- JPBOLDYMar 19, 2019StarI need a different router that will be mainly for WiFi, I need the orbi not to clash with it, unless it's possible to just keep it in router mode and change the WiFi channels they use.
But ideally I need this new router as primary for time being
