n4cho's avatar
n4cho
Apprentice
May 26, 2019
RBR50 Backhaul Satellite Issue?
I have two satelites (RBS50) connected to my RBR50.  One of these is wired via an ethernet cable run back to a switch which is connected to the RBR50.
The wires sattelite is connected and devices connect to it without issue however it isnt listed as a satellite in the attached devices tab.  Instead it is listed as an attached device which has a wired connection.  Its mostly annoying but I was curious if anyone else has this issue?
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is the Mfr and model# of the ethernet switch if one is in the configuration.
    Daisy Chaing disabled? It should be for wired RBS connections.
    Single SSID broadcast?
