gobananasnet's avatar
gobananasnet
Apprentice
Oct 10, 2020
RBR50 "Connection Hell" since the new firmware update v2.5.2.4
RBR50 "Connection Hell" since the new firmware update v2.5.2.4. A few days ago everything seemed ok, all 30+ devices were connecting. Now since the firmware updated a few days ago 75% of our 30+ devices have a great deal of trouble staying connect. No change in devices or their locations. HELP!
  • I just updated the firmware manually to v2.7.0.70, and that only updates the main router and not the satellites. Apparently that manual firmware is only for the router as the satellites rejected this version when attempting to update them manually too, all via the web interface. Also, it has not helped connectivity. Most of our security system is down and many other important devices too. This is crazy making. HELP!
    • Mikey94025's avatar
      Mikey94025
      Hero
      There are separate firmware downloads for RBR vs. RBS.  If you try to upload the RBR firmware file to an RBS it will fail as incompatible.  Make sure you download the RBS50 firmware file from https://www.netgear.com/support/product/rbk50.aspx#download, unzip it, and select that file when manually updating each satellite.
      • gobananasnet's avatar
        gobananasnet
        Apprentice
        Thanks, yes, I'm well aware of that. It was successful for the main router, but the Satellites it is not yet made for them it seems, only works on the router at this time. Satellites remain v2.5.2.4. Thanks
  • FURRYe38's avatar
    Be sure you power OFF the RBR and RBS for 1 minute then back ON after a FW udpate. IF you still notice odd problems, try a factory reset and setup from scratch and check again.
      gobananasnet
      Apprentice
      I had already done all of that. That problem remians unchanged. UGH!
      • FURRYe38's avatar
        Revert back to v16 on the RBS first, then RBR lastly. Reset and setup from scratch.
