hbertrand
Oct 05, 2018Follower
rbr50 connection problem
I am about to repackage this and return it tomorrow. The instructions are trouble, can find # for support, tells you to register, which I did for free 90 day tech support but keeps sending back to re...
ekhalil
Oct 07, 2018Master
You don't need to scan the code if you don't want to!
When the router is up (stops flashing white) then connect (using your computer or other device) to the wifi network that is called ORIxx or something like that, use the code that is printed on the label on the router (under the QR code).
Then you can use your browser to connect to the router by going to orbilogin.com
Good luck!
