dentnvr6
Mar 15, 2020Star
RBR50 constantly dropping of wireless connection
Good afternoon, i'm out of options i have an orbi rbr50 with 3 satellites. my house is 250m², i think that's about 800square foot, two floors. Since the start (about a month ago) my wireless n...
Retired_Member
Mar 15, 2020More info is required....
Modem type/model?
Orbi firmware?
- dentnvr6Mar 15, 2020Star
current firmware is 2.5.1.8 but i have tried 2.3.5.30, same results
my isp router is a compal cv8560E, in bridge mode
- Retired_MemberMar 15, 2020
lots of discussion about bridge mode in the search section.
try this:
my isp router is in bridge mode, my orbi is in normal router mode.
before this setup i tried with the isp router normally, and the orbi in both router mode and ap mode, both gave the same frequent disconnects
you may want to start over. there are know issues with the .18 fw version.
does the compal cv8560E have wifi built in? if it does, and you need to use it, then either the orbi or the compal cv8560E will need to be in the AP mode. Not both.
I actually have started over, I downgraded to v30 firmware, had same problems, re-upgraded to the .18 fw and still having same issues.
the compal is bridged, the orbi is in router mode
- FURRYe38Mar 15, 2020Guru - Experienced User
Since your modem is in bridge mode already, then Router mode is needed on the RBR. There is not double NAT in this condition. This would not be a cause of your wireless problems.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925Has a factory reset and setup from scratch been performed since last FW update on v2.5.1.8?
dentnvr6 wrote:current firmware is 2.5.1.8 but i have tried 2.3.5.30, same results
FURRYe38 wrote:Since your modem is in bridge mode already, then Router mode is needed on the RBR. There is not double NAT in this condition.
having 2 routers is a double nat condition without proper config
