Beaver77's avatar
Beaver77
Follower
Aug 05, 2025
RBR50 dead?
Power outage for a bit and now router will not work….i plug it in and the power light is green but the ring never lights up on top….i dont have it plugged into the modem but it should light the white ring up without the modem attached correct?  I have tried the reset methods and it just stays a steady green the whole time I am sticking a paperclip in the hole….time to upgrade I guess thanks
1 Reply
  • FURRYe38's avatar
    Disconnect the RBR from everything, with the power adapter connected, try a 30-30-30 reset on the RBR. Have a Stop watch running on a phone or pad to track the time and presses of the reset button.
