jim8181
May 03, 2018Guide
RBR50 Disconnecting Frequently
for days = 1 to 5
for daily =1 to 7
All of a sudden, RBR50 says "not connected to the internet"
I reboot both router and sattelite and it's up.
4 hours later, it stops ...
May 03, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem? Any router here by chance?
Any other wifi nieghbors near by? If so, how many?
After factory reset, are you loading a saved configuration from file or setting up from scratch?
- jim8181May 03, 2018Guide
Router : FIOS G1100 modem
At factory reset : A complete reset, nothing from a config file, a completely new setup.
3 networks around me in the neighbourhood.
A 12 year old DLINK router running 802.11b from my nearest neighbour
A weak signal about 400 feet away running
Some inconsequentially weak signals from over 150 meters away.
Thanks
