jim8181
May 03, 2018Guide
RBR50 Disconnecting Frequently
for days = 1 to 5
for daily =1 to 7
All of a sudden, RBR50 says "not connected to the internet"
I reboot both router and sattelite and it's up.
4 hours later, it stops ...
May 03, 2018Guru - Experienced User
Also swap the LAN cable between the modem and router.
Can you still access the routers web page whe this happens? Both wireless and wired?
Try setting a manual channel on 2.Ghz to 1, 6 or 11 and 48 on 5Ghz.
Please try using the DMZ on the modem or bridge the modem and see if this continues...
jim8181
May 03, 2018Guide
First thing I did was to change the cable.
Both with old AND new cable i could access router page.
I don[t think changing the channel will help. As the connection between the FIOS Gateway and Orbi was lost.
BUt... will try it when I go home.
Thanks!
- FURRYe38May 03, 2018Guru - Experienced User
Ok wanted to make sure. Yes seem like this is narrowed down to the modem and router.
Let us know how it goes...
