jim8181
May 03, 2018Guide
RBR50 Disconnecting Frequently
for days = 1 to 5
for daily =1 to 7
All of a sudden, RBR50 says "not connected to the internet"
I reboot both router and sattelite and it's up.
4 hours later, it stops ...
jim8181
May 03, 2018Guide
First thing I did was to change the cable.
Both with old AND new cable i could access router page.
I don[t think changing the channel will help. As the connection between the FIOS Gateway and Orbi was lost.
BUt... will try it when I go home.
Thanks!
May 03, 2018Guru - Experienced User
Ok wanted to make sure. Yes seem like this is narrowed down to the modem and router.
Let us know how it goes...
