jim8181
May 03, 2018Guide
RBR50 Disconnecting Frequently
for days = 1 to 5
for daily =1 to 7
All of a sudden, RBR50 says "not connected to the internet"
I reboot both router and sattelite and it's up.
4 hours later, it stops ...
Brain29
May 05, 2018Apprentice
I have the same issues
Try disabling
Advanced - > WAN setup -> Dos Protection
also uncleck WMM in the wireless settings
I have gone from 1 day orbi crashes to once a week still horriable but more manageable
for some reason youtube/netflix/amazon allot more major sites are blocked by dos protection throwing false positives I'm guessing its filling up the memory or something
- FURRYe38May 05, 2018Guru - Experienced User
What is the Mfr and model# of your ISP modem? Cable or DSL?
This happening over wired or wireless connections or both?
What FW version is your system using?
Try disabling
