jelyma
Nov 29, 2016Initiate
RBR50 does not see USB-connected Seagate HDD.
ORBI RBR50 does not see USB-connected Seagate HDD (4tB). It does show up when direct-connected to PC. Is there a 2-tB limit and will it work if partitioned?
- Nov 29, 2016
The USB port on the Orbi is not currently enabled, so nothing plugged into it will work.
The fact that it exists would seem to imply that it will eventually be enabled for use, but I have not heard of any promises or timeline for that.
Hydro130
Nov 29, 2016Luminary
