ff69
Jun 16, 2020Aspirant
RBR50 Drops Connectivity and keeps rebooting - very unstable
RBR50v2 connected to a SB8200 Modem.
Device configured with 1 satellite. 5 Wired connected PC and devices (ROKU). 3 5GHz wireless devices and 2 2.4 GHz (Thermostat Honeywell and Ring)
Main Router keeps rebooting at random several times a day - cut all internet access and restart.
Tried many things. Everything the same. It just stops the connection to the internet and reboot/restart.
Of course all my conferences stops and internet access is suspended.
Did all kinds of things following the numerous posts on this forum. Nothing changes. My previous router never dropped connexion once. What is the point really. Very close to returning this monumental waste of my time and resources.
Perf is good when it is on.
There are other users on 2.4 GHz channels. Tried to select specific channel but that does not fix it.
Any suggestions?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- ff69Aspirant
V2.5.1.16
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerOther side of the House, one level below (so at least 40ft)
Any Wifi Neighbors near by? If so, how many?Currently Manual on 2.4GHz = 11(P)+ 7(S)
5G Channel 36+40+44+48(P)
Lots of wifi neighbors but spread 1-2 per channel (27 different signals detected)
WMM enabled on both 2.4 and 5 GHzBeanforming enabled
MIMO -> Set to Enabled
Preamble -> Reset to short on both
CTS/RTS is 2341 0n 2.4
CTS/RTS is 2345 on 5
Has Power at 50% on 2.4 ->100%
No Armor
No Daisy Chain
No Fast Roaming
No IPv6
No coexistence
My Setup (Cable 900Mbps/50Mbps)>CM1100>Orbi RBK50 v2.5.1.16 and Orbi RBK853 v3.2.11.2(AP Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK852, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111Rebooting...- FURRYe38Guru - Experienced User
