edthesprinter's avatar
Apr 25, 2020
RBR50 Drops WiFi Roughly Every 6 Days
Hi,
About every 6 days, my ORBI RBR50 WiFi stops. I have to reboot to get things going again. Anyone else having the same issue? Firmware version is V2.5.1.8
  • FURRYe38's avatar
    This isn't a FW issue. More like a interference issue or configuration issue.
    Also there is newer v16 FW available as well to try...
  • Retired_Member's avatar
    Retired_Member
    edthesprinter wrote:
    Hi,
    here's your problem.........Firmware version is V2.5.1.8
    get rid of it
