presidentskroob
Jul 18, 2018Tutor
RBR50 experiencing slow wired connection and frequent router reboots
I purchased the RBR50 some months ago, and I've recently begun to see two significant issues, one that I think people have quite a bit of experience with (frequent router reboots, even on the latest ...
Jul 19, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem the Orbi is connected too?
I would do a Factory erase and set up from scratch. I would first set up the router, dont' enable the speedtest app on the router. Just set it up and run a couple of tests from the PCs first...
- presidentskroobOct 20, 2018TutorI had been putting off the factory reset for a while, but the router somehow reset itself two nights ago and I had to set it up from scratch. The issue still persists. The router periodically reboots for no apparent reason, and that seems to coincide with torpedoing the network speeds on my wired machines. I restart the wired machines and they get their normal speed again.
- FURRYe38Oct 20, 2018Guru - Experienced User
Last resort you should try this:
- presidentskroobOct 20, 2018TutorThe current modem is a Technicolor CGM4231 operating in bridge mode. I don't recall what the previous one was before I swapped it for this one. Actually, now that I think about it we have had a total of three modems over the life of this issue, as the one I was using when I opened it died and I picked up this latest one from the ISP. I have already updated the firmware on the router. It's the latest 2.2.1.210 as noted in that release item.
