Ergates's avatar
Ergates
RBR50 Firmware - Conflicting Info
Hi Community,
My Orbi says it's up-to-date...
But I'm not sure...
Grateful for any advice, thanks.
Rgds,
Andy
  • You're a version behind but I wouldn't necessarily be in a rush to update as we've seen a few stability issues on the newer version.
    You can always make a backup and try manually updating if you want to be on the newer version.
  • Hi Community,
    My router tells me it's up-to-date...
    But I'm not sure...
    Any advice gratefully received...
    Thanks,
    Andy
    • Ergates's avatar
      Ergates
      Apologies, just realised I posted this in the wrong section so have re-posted in the Orbi section...
    • plemans's avatar
