phlying1
Oct 04, 2023Aspirant
RBR50 Firmware downloads the wrong file (RBR50V2)
The download to manually update my RBR50 (https://www.netgear.com/support/product/rbr50#download)
downloads the wrong file. It downloads RBR50V2 and then the manual updload fails.
Please provide the right file so that I can update the firmware. V
VERY FRUSTRATING!!!!!!!!!!!!!!!
- If you can get it connected to the RBR or connect it via ethernet to the RBR, log into it's web page and get it updated manually. - Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
 Enjoy. 📡
