ShamanTee's avatar
ShamanTee
Follower
May 10, 2019
RBR50 firmware not updating
I have the RBR50 router, firmware version 2.2.0.66, but when I 'check for updates' via the app, I get the message 'There was a problem checking firmware update'.  Any suggestions?
I saw one suggestion to update the satellite before the router, but I only see the router listed in the settings on the app.
Welcome any suggestions.  Thanks.
  • Have you tried checking Firmware Update via desktop PC or Mac?
  • FURRYe38's avatar
    Try manually downloading the FW files for the RBS and RBR and apply them manually using a web browser. Be sure to update the RBS first, then RBR.
