sweerik
Sep 23, 2022Aspirant
RBR50 looses internet connection
RBR50 with firmware 2.7.4.24 and 3 RBS50 and 1 RBW30 satellites looses internet connection intermittently.
Local wifi and satellites works fine but the router just stops to be connected to Internet. LED indicator turns PINK.
Reboot and power off doesn't solves the problem, Only a reset on router and a fresh installation of router brings internet back.
Problem started September 6'th and has required a hard reset and installation approx once a week. Previous years very stable without problems.
No changes in ISP configuration, excellent support with no problems identified. Fiber. Internet phone on separate IP works well, as well as temporarily switching to a Netgear Nighthawk router. The problem seems to be with Orbi RBR 50 router.
Any suggestions? Any changes to settings? Firmware problem?
Thx
- ekhalilMasterIs Orbi in Router or AP Mode? What is the make and model of the ISP router to which Orbi router (RBR50) is connected?
 - GlenndebresserAspirant
hello,
last week my router+ sattelites did also update to the new firmware version now 1 a 2 weeks later i have a comparable problem like you
my satelites works fine but my router stops working the wifi of the router/base doesnt work anymore and plug the cable direct in the router/base doesnt give ethernet also
is this a software problem?
