Mountainview1
Mar 06, 2019Follower
RBR50 Moving Homes
Apologies if these are silly questions:
Just moved homes (from neighborhood where internet had to come from cellular hotspot) to house with 400 mbbs download.
(1) Spectrum installer left both cab...
- Mar 07, 2019
CrimpOn wrote:
In addition, many contributors recommend putting the Spectrum modem/router into "pass through mode" so that you have only a single router between your devices and the Internet. It is not strictly necessary, but there are specific features that you may want which do not work with two routers hooked together.
More than just "recommend". Unless you want problems it is strictly necessary.
Having two routers side by side is a recipe for chaos and confusion.
See the message fromFURRYe38
Their option 1 is the best choice.
Mar 07, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
(1) Spectrum installer left both cable router/wifi enabled (2&5g) and attached the Orbi RBR 50 (which Im relatively certain is broadcasting on same or similar frequencies.
Should I disable to cable modem's wifi signals for fear of conflict? ... and
(2) Should I return the Orbi to factory default settings since I am working with new internet source upstream? As it stands, I can get wifi reception from pathways provided by both systems but I want to optimize reception.
Thanks much
