DaleLyles's avatar
DaleLyles
RBR50: no firmware update from 2.7.2.104?
My wifi has been a bit flaky, and finally I checked the firmware on the devices. The RBR50 is running firmware version 2.7.2.104, as is one of the satellites (RBS60); the other satellite (RBS20) is running 2.6.2.104.
The support page for the RBR50 says there is a firmware update, 2.7.3.22, and provides a link: https://kb.netgear.com/000063811/RBR50-RBS50-Firmware-Version-2-7-3-22?language=en_US
However, the Orbi app on my phone either cannot "find" the router or if it can, says there's no update needed.
If I got to orbilogin.com, I am told that my wifi system is not connected to the wifi network, though it clearly is. (The phone app says so.)
Finally, logging in via the IP address, I am told this:
What gives?
  • Don't try to open the .img or .chk files. They are not usable my any OS. Just use a web browser and log into the RBS/RBRs web pages and use the FW update feature page to send the unpacked FW files to the RBS then RBR.
    DaleLyles wrote:
    I downloaded that somewhere at the beginning of trying to figure this out, but my Macbook Pro does not recognize it as a file and won't open it.
