Inboxsga
Jul 26, 2019Follower
Rbr50 no internet connection issue
Getting following issues every time I enter home. WiFi does not connect itself and when I try explicitly it shows me WiFi but gives this message of no internet connection. I have installed this system...
Jul 26, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What wireless devices are you having problems with?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Inboxsga wrote:
Getting following issues every time I enter home. WiFi does not connect itself and when I try explicitly it shows me WiFi but gives this message of no internet connection. I have installed this system just last week. Working fine with wired devices and other device always at home. Only issues is the phones as we move out and come back to WiFi.
