bsterling's avatar
Mar 08, 2021
RBR50 No internet from ethernet ports
This weekend I lost internet connection for everything connected via ethernet in my main unit.  Wifi still works great.  I do have a switch and it still shows connections, just no internet.  I have tried connecting a laptop straight to ethernet connection on Orbi, and it connects but no internet.  I have tried all the connections.  Router version is V2.7.2.104.  None of my devices show up as "wired" anymore.  Thanks in advace.
  • FURRYe38's avatar
    What wired devices do you have connected?
  • you may want to roll your firmware back.
    lots of problems being reported with V2.7.2.104.
    • bsterling's avatar
      bsterling
      Tutor
      Thanks guys- I will try a rollback first and then will do a factory reset.  Very interestingly, the ethernet ports on the satellites work...
      • vajim's avatar
        vajim
        Master
        excellent idea
  • FURRYe38's avatar
    Seems like a hardware failure at the RBR. :smileysad:
      • FURRYe38's avatar
        Hope you can find a replacement RBR.
        Good Luck.
