ColinT's avatar
ColinT
Follower
Jan 24, 2018
RBR50 Not restarting
Last night around 2am my router stopped working. It is now in perpetual “white blinking” mode, and never appears to properly boot up. Have others run into this? I checked my cable modem and Ethernet connection to the router, both are working fine.
1 Reply
  • Retired_Member's avatar
    Retired_Member
    You might try:
    1.  Re-boot the modem and Orbi router
    if that doesn't work and if feel you've given it plenty fo time (?), perhaps try a reset on the Orbi router.
