toofast
Dec 02, 2025Tutor
RBR50 out of nowhere is losing connectivity 5-7 random times a day
So, I am relatively technical and out of nowhere by Orbi Mesh has lost its mind. Spent two weeks with Spectrum to make sure everything is perfect between the Node and my House and then with Spect...
Dec 02, 2025Guru - Experienced User
Does the connectivity return on its own?
If not, what are you doing to restore it?
toofast wrote:Does the connectivity return on its own?
Yes - EVERY TIME !! - Which is even more insane to me.
Can you tell if you still have local connectivity when the problem occurs? (just wondering if the WAN port connection is what is dropping, or if it is more than that).
toofast wrote:Was there a "recent" firmware upgrade - from this link I can't seem to find the RBR's
This says you are running the most recent firmware:
- https://www.netgear.com/support/product/rbr50
