toofast
Dec 02, 2025Tutor
RBR50 out of nowhere is losing connectivity 5-7 random times a day
So, I am relatively technical and out of nowhere by Orbi Mesh has lost its mind. Spent two weeks with Spectrum to make sure everything is perfect between the Node and my House and then with Spect...
toofast
Dec 02, 2025Tutor
I am not sure why my REPLYs keep disappearing, so this is out of order.
As you can see, the WLAN access came back.....
that address is not on my Orbi
- tweedaleDec 02, 2025Aspirant
So I have followed your thread a bit. Pretty much same setup, Spectrum CABLE, ORBI 3000.
My issue that that like clockwork, every 10 minutes the Orbi seems to be doing a reset and I would lose connection to Pluto.
Had read online that Access Control seemed to be wonky after updating to FW 2.7.5.6 and that is when I started having this issue. Disabled AC but problem persisted after a few days and AC does not seem to work correctly. Was hoping this was widespread and Netgear would have released a patch to Firmware.
I notice it while watching PlutoTV when connected to the satellite either via wired port or WiFi.
Found out tonight If I plug in direct to Cable Modem everything works fine except of course I no longer have my Orbi mesh throughout my house.
Will troubleshoot the satellite and maybe revert back one FW version. Will report back.
- tweedaleDec 03, 2025Aspirant
Did a manual FW update to V2.7.5.6 on satellite then router. Same issue...reset every 10 minutes
Did manual update to V2.7.5.4 on both and viola. No more resetting every 10 minutes.
- toofastDec 03, 2025Tutor
Wow...so now we need Netgear to figure out what the heck is going on...oh wait, they wont though, because they want you to buy new devices. (i get it I guess, but geez)
Mine has been stable (0 drops) since cleaning out the nonsense on Access Control. (who knows if that is related)
I am wondering if I stick with 2.7.5.6 or not....mmmmmmmmm
