toofast
Dec 02, 2025Tutor
RBR50 out of nowhere is losing connectivity 5-7 random times a day
So, I am relatively technical and out of nowhere by Orbi Mesh has lost its mind. Spent two weeks with Spectrum to make sure everything is perfect between the Node and my House and then with Spect...
Dec 02, 2025Guru - Experienced User
From what I see from the specs, the laptop doesn't have a ethernet port unless you have a USB to ethernet port adapter connected.
Make sure the laptops wifi is disabled on the laptop.
Check the wifi adapters MAC addresss on this laptop as well to compare.
