toofast
Dec 02, 2025Tutor
RBR50 out of nowhere is losing connectivity 5-7 random times a day
So, I am relatively technical and out of nowhere by Orbi Mesh has lost its mind. Spent two weeks with Spectrum to make sure everything is perfect between the Node and my House and then with Spect...
toofast
Dec 02, 2025Tutor
yes I was using the Ethernet from a Microsoft "dock", but honestly that Ethernet stopped working about a year ago and I still have not figured out why. so all I have is WIFI.
i can disconnect wifi on this laptop, and get my son's and then clear logs And see if that stops...would that help ?
Ran ipconfig / all and no mac address matches.
Dec 02, 2025Guru - Experienced User
Would be quick check to make sure.
You may need to physcially go and take a look at ALL devices and there MAC addresses and see if something appears.
Be sure to check for any devices that maybe ON or seemingly connected by may not be and may keep trying to connect with a wrong PW.
Check to see if that MAC address appears in the Access Control list and select it to block only this one device and see what happens.
