toofast
Dec 02, 2025Tutor
RBR50 out of nowhere is losing connectivity 5-7 random times a day
So, I am relatively technical and out of nowhere by Orbi Mesh has lost its mind. Spent two weeks with Spectrum to make sure everything is perfect between the Node and my House and then with Spect...
toofast
Dec 02, 2025Tutor
I am at a loss...within 5 seconds of refreshing logs on a backup laptop, same issue.
[WLAN access rejected: incorrect security] from MAC address 0c:23:69:8f:0a:7c, Tuesday, December 02, 2025 14:39:11
[Log Cleared] Tuesday, December 02, 2025 14:39:06
that mac address does not exist in access control on the ORBI
how can a device magically find the new ssid - could this be coming from Orbit itself ?
could it be something from Spectrum - somehow their Modem...even though that seems impossible ?
- FURRYe38Dec 02, 2025Guru - Experienced User
And this is with original SSID name or new SSID name? If using original SSID, may want to give a new SSID name a try.
RBS is OFF?
May need to visiualy inspect all of your devices. ISP modem is ethernet and not wireless.
Give a factory reset a try as well.
