toofast
Dec 02, 2025Tutor
RBR50 out of nowhere is losing connectivity 5-7 random times a day
So, I am relatively technical and out of nowhere by Orbi Mesh has lost its mind. Spent two weeks with Spectrum to make sure everything is perfect between the Node and my House and then with Spect...
toofast
Dec 02, 2025Tutor
Ok so update
Plan is to Factory Reset, but in the meantime I add a new SSID that was still getting that strange WLAN access rejected from a PHANTOM MAC Address
My DSN change to CloudFlare however did not stick....
So I finally fixed that and now I no longer get the WLAN MAC issues, but I see this issue, which I cant figure out yet
[admin login] from source 192.168.1.2, Tuesday, December 02, 2025 17:07:45
[admin login failure] from source 192.168.1.2, Tuesday, December 02, 2025 15:56:54
[admin login] from source 192.168.1.2, Tuesday, December 02, 2025 15:55:21
[admin login failure] from source 192.168.1.2, Tuesday, December 02, 2025 15:48:32
[admin login] from source 192.168.1.2, Tuesday, December 02, 2025 15:48:02
[admin login failure] from source 192.168.1.2, Tuesday, December 02, 2025 15:34:01
[Log Cleared] Tuesday, December 02, 2025 15:33:16
HOWEVER, since I finally made sure the DSN change stuck...I have been up for 2 hours.
Next move is to revert to original SSID and then Factory reset after I get my family settled.
WHEW, what a Journey
Dec 03, 2025Guru - Experienced User
toofast wrote:[admin login] from source 192.168.1.2, Tuesday, December 02, 2025 17:07:45
Possibly an old saved admin password on 192.168.1.2?
- toofastDec 03, 2025Tutor
Yeah, I still have not figured that out...192.198.1.2 point to an IIS service running....
But I turned all that off....
Now I am seeing this form the Logs in Orbi...that is ME logging in a few min ago...so ORBI thinks my laptop is 192.198.1.2 - which makes no sense. I was not failing my log ins.
[admin login] from source 192.168.1.2, Wednesday, December 03, 2025 11:22:16
I will keep monitoring and see what I can see, but so far this does not seem to affect anything.
