Nasshop's avatar
Nasshop
Tutor
May 03, 2021
RBR50 Position
I live in a long narrow single storey house that has solid walls. Siting the Orbi router and satellites is tricky to get them to connect and provide adequate coverage. The loft is continuous and open from end to end. Would the Orbis operate better sited in the roof space? I'm thinking that the WiFi signal from each device would need to be 360 degrees for this to work.
    • Nasshop's avatar
      Nasshop
      Tutor
      Thanks Furrye38, that's helpful.
      My home is about 2500 sg ft. Due to the solid block walls the devices cannot be ideally placed for WiFi distribution as they won't connect. I currently have them daisy chained and the WiFi signal isn't too bad but not optimal.
      The images in your first link suggest the signal is 360 degrees from each Orbi so I will try them in the roof space where they will be about 30 ft apart, in a straight line and in sight of each other. The signal will need to travel only through plasterboard ceilings into the rooms below. I've only held off trying it so far as I'll need to do some wiring of power supplies and Ethernet beforehand.
      • FURRYe38's avatar
        Yes each unit broadcasts in 360 degree pattern. Something you'll need try and see if your idea works or not.
