DougKaufman's avatar
DougKaufman
RBR50 Problem
Hello I have a RBR 50 Orbi Base and 2 RBR 50 satellites. I have used them for about 18 months and it sbeen fine. Then last week, it stopped working. The base can't hold a connection to the modem for longer then a few seconds. When it is connected the speeeds (Up and down are perfect) but then it won't stay connected. And the satellite's won't connct to the base. Actually they will signal blue that its connected but it never connects according to the app. I called Netgear and they were not helpful at all. I'm stuck with a $750 mesh systen that isn't working. Anyone have any ideas?
Thank you.
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Hi DougKaufman
      Welcome to NETGEAR Community!
      How often does it disconnect? If issue re-occur, please bypass the router and check if you have connection straight from the modem.
      Blanca
      Community Team
      • DougKaufman's avatar
        DougKaufman
        So I called Netgear support last week and the person wasn't helpful. I called in again and they said to leave a vm and someone would call me. 3 days later, no one had called. Last night I was on with their Technical support for 3 hours and still no solution.
        Something that came up that was very confusing to me was the situation where netgear told me they would work with me to get my system running again, but then I had to pay $150 and they would refund me that money in 8 months. I've never heard of that. The people on the phone could not give me a straight answer as to why that policy was in place. Anyone understand that?
