dnh3155
Feb 23, 2019Tutor
RBR50 Problem
This system is a disappointment, I tried to sign into the community, but can barely stay online long enough to do it. Then, I signed in three times, and immediately receved the message that my session timed out. One of my satellites stopped functioning. I made 5 calls, spoke to 5 different people, and spent over 2-1/2 hours on the phone, trying the same things over and over, until it was finally agreed that my satellite needed to be replaced. On the third call, I started mentioning than my system wouldn’t stay connected to WiFi. Now, I have to reconnect every few minutes. The system worked great for about 4 months, now is barely functional. I googled this problem, and it appears that many have the same complaint. I’ll be fortunate to stay online long enough to publish. We have a larger home, and this seemed to be the best mesh system to cover the square footage. Is anyone in the community having the same trouble? Any solutions?
- ekhalilMaster
Can you please give use more information about your setup so we can try to help:
- What ISP modem/router are you using?
- Is Orbi in Router or AP Mode?
- What wired and wireless devices do you normally have connected to Orbi?
- What wifi channels are you using in Orbi and how does the wifi radio look like in your surrounding?
- Chuck_MMentor
Did your original ISP modem have a wireless capability? Is it still there? What is the make/model of it.
Probably a simple solution to your issue, so although frustrating, there is hope.
- dnh3155Tutor
Thanks for your response.
I have an Arris modem. When I started having problems, Comcast told me I had to be in bridge mode. That didn’t help matters. I got notice this morning that there was a firmware update for Orbi. I did the update, turned off bridge mode on the modem, and changed router mode to MP. Not sure if this is the entire solution, but I’ve been online for over two hours with no interruption. The longest in over a week. Fingers crossed.
