presidentskroob
Mar 31, 2020Tutor
RBR50 providing poor (<5mbps) download speeds to entire network (both wired and wireless)
I've had an Orbi RBR50 for about two years. For some reason, it has started to provide incredibly slow speeds to the devices on the network. My service package is for 200mbps download, and if I plug ...
Jack1963
Apr 12, 2020Aspirant
I'm also experiencing issues with the Orbi speeds just in the last week. Have had the system for over 2 years with no issues and fast speeds but suddenly not so much. I've been trying everything, resetting, changing settings, etc. with little results.
- FURRYe38Apr 12, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?Speed test via wired working?
What device are you using to test speed?
Please try a factory reset and setup from scratch with the RBR and RBS.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
https://community.netgear.com/t5/Orbi/Orbi-Satellite-Drop-Connection-time-to-time/m-p/1890341/highlight/true#M88026
Jack1963 wrote:I'm also experiencing issues with the Orbi speeds just in the last week. Have had the system for over 2 years with no issues and fast speeds but suddenly not so much. I've been trying everything, resetting, changing settings, etc. with little results.
- Retired_MemberApr 12, 2020
FURRYe38 wrote:What Firmware version is currently loaded?
:smileymad:
